what is this plug for
rotorracing
Car: all kinds
rb25thanks for the help
Modified by rotorracing at 9:30 PM 4/24/2009
240daveTX
Car: 2005 Nissan Titan LE
1993 Nissan 240SX Convertible
looks like the factory boost pressure sensor.
i may be wrong though
rotorracing
Car: all kinds
thats the other one..to the right
the gray injector wire runs in to the this plug ...and the car is not firing. no injector power
Modified by rotorracing at 3:42 PM 4/24/2009
rotorracing
Car: all kinds
if u need it bigger .. but with out arrows http://www.gweeds.net/carpage2/rb25diagram.jpg
Modified by rotorracing at 4:31 PM 4/24/2009
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
flux capasitor connector!
i think that that is the windsheild wiper amp connectror, but i could be wrong
rotorracing
Car: all kinds
no sorry that's on the other side .. the injector 12v power wire goes in to this clip... my injectors are not firing off.. if u spray starter fluid in it fires up.. i need help please ...
d356bud
Car: 1990 240sx w/ RB25DET
I believe that connector is junk. I removed it completely from my setup
d356bud
I have my injectors getting power from the same place as the coil packs and its been working fine for me for over a year
rotorracing
Car: all kinds
i ran the injector power to the wiper power, pin 4 on the ka dash harness.... that way its keyed on (its a race car done need wipers).. so its getting power but they are not firing.. i have mounted the ecu so its grounded and checked all my wiring from 3 diff people.. it will start with starter fluid
scarboroughdub
take that grey wire out, and wire it into a switched 12v source that can carry atleast 15 amps.
this wire gives power to your injectors.
done and done.
rotorracing
Car: all kinds
thats what i did ... it is to the 12v wiper!!i took the crank angle off and spin that and it sounds like the injectors fire but when i crank i think they are not firing.. its hard to tell with one person. my friend is on his way
