what is this? pics*
sdtouge
Car: 1990 240sx coupe
i dont know wht this is, but i know its broken...
also, if anyone has one for sale...
i can take more pics if needed, the lighting was kinda wierd.
sdtouge
another
sdtouge
number 3, its in the center of all the pics...
sdtouge
and finally,
BoroBoroS13
Car: S13, RS13, and S14
PCV valve and you can buy one for a CA18DE and use it on your motor.
rico05
Car: 1992 RMS13 w/ CA18DET
FICD. It bumps the idle up when you turn on the A/C. I don't have A/C, so if you can't find one for sale (any Pulsar NX SE w/ a CA will have one) I could pull mine off the AAC and fill the hole. It would be a real pain for me to do, so try to find one somewhere else, but if you can't and you want to keep your A/C (if you ditch the A/C you don't need it) lemmie know!
[email protected]
Modified by rico05 at 2:16 AM 2/27/2005
sdtouge
i think its closed, and i am not gonna have ac, so what does this mean?
biosehnsucht
yes, FICD, not PCV.
its normally closed so its not going to cause a problem if its broken off. mine is too, I have a replacement but until I get AC hooked up no point installing it.
pulsar gtr
Car: NISSAN VEHICLES
Yes, it is the FICD seloniod, Any nissan engine has one, KA engine or pulsar ca16de or ca18de, as well as VG30DE/TT engines, all have the same sensor which you can use.
Most of the CA18det engines that I get usually have this sensor is broken, as when they put the engine in the container in Japan, they put a board on the top of it so they can put more engines on the top, so since this part is the highest point of the Ca18det engine, it tends to break.
PULSAR GTRRafi
sdtouge
so i dont need to replace it? should i disconnect it from the harness or just leave it to dangle?
thanks
pulsar gtr
If you aren't going to replace it, I would definitely remove it from the harness plug as it has 12V when ever the engine is running.
PULSAR GTRRafi
sdtouge
sweet. thanks alot guys.
matt
BoroBoroS13
Oppppz, sorry about that mistake.
redamnavit
Congradulations, you're number 1,000,001 (including me) in the list of people who got a CA clip with a broken FICD. As others said though, its no big deal.
sdtouge
thank you. i feel honored.
