what is this part called?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
kahlilj
Car: 2006 FX35
My friend has a 2011 QX56 which has a loose part hanging under the front end. It's a metal piece and appears to be a deflector plate/shield of some sort? We looked online and could't find an illustration with an exploded view or what the fastening screws were. does anyone know what this part is? Or where online we can find an illustration with part names/numbers?
https://www.dropbox.com/s/hzdnv7ephlwyj ... .jpeg?dl=0
https://www.dropbox.com/s/66jcfkqkfg6j9 ... 4.mov?dl=0
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
How to upload pictures on NICOclub:
using IMGUR
using TINYPIC
kahlilj
Car: 2006 FX35
Rogue One wrote:
Mon Jul 02, 2018 4:04 pm
using IMGUR
using TINYPIC
Thanks. but I can't go back and edit the post now
Sooo do you know what the part is called? or are you unable to click the link and see the image in my post?
jayb123x
Car: 2008 QX56
Looks to be the skid plate and the rear two bolts that holds it on are missing. Has he had his oil changed recently?
kahlilj wrote:
Mon Jul 02, 2018 2:40 pm
kahlilj
Car: 2006 FX35
jayb123x wrote:
Fri Jul 06, 2018 4:57 pm
Thanks jayb. I am unsure if the oil was changed recently. I seem to recall it might have been, but I will ask. Is this a part that need to be removed in order to change the oil?
primov8
Car: '14 QX80
aFe Mach Force-Xp SS catback exhaust
aFe Momentum GT Pro Dry S CAI
aFe Silver Bullet TB spacer
The skid plate has to be removed for an oil change. The (2) rear facing bolts needed to secure the skid plate is this:
Nissan/Infiniti part 01121N8051
kahlilj
Car: 2006 FX35
So no work has been done since April. This hanging plate was noticed in July. Does anyone know the bolt size of those fasteners holding it in place? I looked again online at some part sites,but simply don't see the part shown in any illustrations.
primov8
Car: '14 QX80
I just looked at your vid links again and right at the beginning, I can see the skid plate is missing one of the front bolts that secures it in place. Its the same bolt/part 01121N8051 for all (4) bolts.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
