i hope you mean with vac lines still hooked up and solenoid unplugged. Either way I just bypass the solenoid completely and run a boost line straight to the wastegate...s14kouki wrote:If you dont use it, you will run at 5psi at all times. Or like 300plus said, you can plug it in and use 5psi at low revs and 7psi at higher revs
Then if you use it and ground the wire, you can run at 7psi at all times, common mod for skyline owners
Yes by that i mean running a vacuum line straight to the wastegate, the way you are setup is boosting 5psi.Bluefire wrote:
-Bluefire
Well then thats wrong... with wastegate hooked directly up to boost you should be hitting a full 7psi.. which is where the factory wastegate should open.s14kouki wrote:
the wastegate is a 5.5psi spring, the boost solenoid is what allows it to run 7psi.Bluefire wrote:
I will add that this from what I am showing on my autometer mechanical boost gauge
Modified by Bluefire at 10:26 PM 3/19/2007
