NutriaforBreakfast »
https://forums.nicoclub.com/nutriaforbreakfast-u77129.html
Wed Jul 09, 2008 7:25 am
Could be green dye used to check for leaks.
You could have a bad o ring or the hose could be cracked or.......nothing might be wrong
If somebody slopply put in the green dye and it went all overyour engine compartment accidently then it might not be leaking.
Get some gauges from autozone and test hi side and low sidereading and see how long a vacuum will hold.
