Thanks for a clear answer. You're exactly right, but I had to hear it before I moved forward. My mechanic says he prefers a US market engine because the JDM motors require a lot of work with all the changeovers. I believe he said it's because of emissions that there are so many things to change over. I know he just did a 93Q a few months ago. Does that sound valid? Has that been your experience?Q45tech wrote: JDM takeouts are plentiful in LA.........[last week there were over 10 to chose from in ATL].
Step one: Find out if there is a JDM warehouse in Seattle, some company that specializes in importing Nissan junkyard motors from Japan to avoid freight from LA [plus the trip to LA to inspect and evaluate possible units].
Your oil pump will be trashed [and need replacement]. the parts will cost close to what a JDM engine costs
You must buy a complete chain guide kit plus new chains [either to use in testing your old engine or/and to put in the JDM take out engine if the results are bad.
You will need to rechain the old engine to rotate it to look for bent valves on driverside, if ok then you must do cylinder by cylinder leak down and compression test.
99 out of 100 times the valves bend.
The $750-$1200 the hand selected JDM engine costs is just the start.........someone must perform 25 hours of work........KS, 30+ hoses, valve cover reseals, new chains and guides, lots of cleaning and misc.
So much easier to do under plenum hoses, KS and harness, and clean plenum, IAC and EGR valves wehn engine is out of the car. Thus cheaper than waiting for the components to fail with the engine in the car and twice the labor charge.Q45tech wrote:We have swapped 25+ JDM engines into US Q since 1995 when we began T3.
Good idea to pull oil pan and regasket and clean examine pickup.
REHABILITATION of any engine [US or JDM use] requires more time and materials than either engine [cost +shipping]. Say $900 in parts and $750 in rehab labor................then the swap labor $750-$1000.
Doing the job correctly so that the newish engine can last another 6+ years cost $4,000 in total...............no short cuts allowed or it just isn't cost effective to swap in the first place. If it fail soon from skipping things or you end up spending $2000 6 months later to do things that would have cost $1000 when out of car.
By the way, he did warn me a couple of times about the chain guides. He also told me not to buy my VR4 before I bought it. He drives an early 90's Mercedes and swears I should buy one. he might be right, but I do love my Q. I had to use a rental car the other day and I got a Dodge Neon. It was HORRIBLE!!!!! It seemed like the car was always straining. I'm 6'4" 280lbs. Maybe my size had something to do with it, but now I know why people who drive those cars always seem to have a sour look on their faces.Q45tech wrote:The JDM vs US engines are identical except for exhaust manifold which takes an hour to swap with brand new gaskets.
Comments like he made, make me wonder how many Q engines he has replaced??????????????????????????????????????????????????????? Toyota and Honda 4-6 require lots out swapping but not Nissan V8
ONE MUST reseal valve covers replace front and rear main seals, all hoses, and gaskets, KS snd harness fuel hoses, runner gaskets........I would also pull and exame injectors and replace all orings.
We see lots of MECHANIC exchanged engines which often require serious after installation rehabilitation costing 3-4 times as much labor in the car vs sitting on an engine stand. CAREFUL CAREFUL CAREFUL
If your MECHANIC is so good why did he alow your engine to fail from chain guides............he should have harassed you constantly.
ALMOST ALL US engines are significantly worse than any JDM take out engine...........abusive US owners and dealers.
