Boost MAP Analyzer by BLITZ. The item is designed to be used in conjunction (plug-and-play) with BLITZ boost controllers, including the Dual-SBC Spec S, Spec R, SBC i-D(I,II, III)
The item is best used for those on the circuit or drag scene with problems with traction during accelleration. The unit has ten MAP settings that takes into account 3 parameters including: boost levels, speed and throttle position.
With the proper settings you will be able to keep a high level of boost while keeping traction and thus keeping an advantage over your competition
this is all the info i found on it can some one tell me what this does clear things up a little.and would the aem ems do the samething thanxz
