C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri Jan 24, 2003 1:15 pm
It will effect your HC emissions if you bypass it. Whatever you do, don't plug it. It will allow exhaust air up into it and eventually corrode the vacuum controlled valve. If you keep it in place, use a breather filter. If you decide to remove it, remove it completely, and plug the hole in the exhaust.
