what is this and wheres it go?
seanman
Car: 1989 Nissan 240sx
like i said, where does this line go and what do i need to hook it up to? redtop sr20 FMIC
Tulsa_S-13
Car: 1991 SR 240sx
It vents the gasoline tank.
Most people that get rid of the carbon canister just simply take off the rubber line and bends down the metal hardline.
Hijacker
Car: '92 240sx Convertible
'94 F-150
That looks like the vapor line coming from the gas tank that goes into the bottom of the charcoal canister. If it's connected to a hard line that follows the frame rail to the aft. I just don't remember that line coming up so high.
seanman
its connected to a hard line that goes back up the fire wall then back under the car toward the rear. theres a line connected to the bottom of the charcol thing that runs into the frame then somewhere from there
CMG
Car: 1989 240sx Hatch w/ Redtop
Are you going to use your emissions equipment? If not then just take it out. I just put a length of hose on the end of the hardline and that's it.
seanman
ok, so should i just take off the canister?
