what is this and were does the vac lines go?
myr32skyline
Car: 1992 240sx coupe se converted to a r32 skyline
i have no idea
float_6969
It is the stock boost controller, IIRC. You've got to do extra wiring to get it to work, and it doesnt' make that much difference, I've tried it.
don't bother with it. Run a vac line from the outlet on the turbo to the wastegate actuator. If it's not the stock CA T25, and you don't have the nipple, then you'll have to run a line from the intake manifold, over to the wastegate.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Either:
- Boost control solenoid Valve for high octane petrol- Power Valve solenoid for 4000rpm.
To find out where the wires and hoses go..download the S13 handbook from zerothread?id=114956.
Cheers
Edited by float_6969. We've got a link to the FSM in our sticky
burnout 180
Car: 1990 s13 180sx ca18det
Its the boost controller
