What Is This and How Do I Fix It? (Pics!)
Ron Burgundy
Car: 1999.5 Nissan Pathfinder 3.3 LE
Went to go change my shocks today and found this...
The part on courtesyparts.com is listed as "BUMPER ASSY-BOUND REAR SUSPENSION."
Is this a "bump-stop"? If so, why does it look nothing like the ones sold on 4x4parts? If this isn't a bump-stop where are the bump-stops? Does the Pathfinder not have rear bump-stops?
It does however look like these....
https://www.4x4parts.com/nissan/coil-sp ... p-349.html
Please Nico... enlighten me!
Pwnin O'Brien
Yeah, that's your bump stop. Why is it contacting your lower shock mount? Are your shocks completely shot?
Ron Burgundy
Why do they look nothing like the "bump-stops" sold on 4x4parts? Seen here...
https://www.4x4parts.com/nissan/inch-ta ... p-584.html
Like I said they do look like the ones referenced in the OP, are those the correct ones?
And I have a few theories as to your questions...
1) It is touching the seat of the rear coil spring because it's so butchered, that it just hangs there and therefore hangs a little low.
2) The rear coil springs are worn and the vehicle sits a bit lower. Shocks only absorb the bounce no? The springs is what keep the vehicle at a proper height.
01silvapathy
Car: 2001 Pathfinder LE 3.5
Yup thats the bumpstop. The bumpstop on 4x4parts.com will not work (pretty sure those are designed for truck with leaf sprung axles). Gotta order from a dealership, a stock replacement.
amaff
Car: 2003 Nissan Pathfinder SE
I "fixed" mine by removing them entirely and installing a pair of AirLift 1000 air bags, and haven't looked back. For more info:
qx4-rear-bottoming-out-solution-t423926.html.
fueler
Car: 2 Nissan's
2 BMW's
i removed mine completely, never installed anything in their place and my rig has been fine...
Pwnin O'Brien
I'm sorry, it was 6am and I was still pretty asleep. I meant to say are your springs completely shot?
fueler
Car: 2 Nissan's
2 BMW's
Pwnin, just out of curiosity, have you ever taken a good look at your bumpstops? I cant imagine a set of bumpstops that ISNT trashed by now.... pathfinder / QX4 springs are so weak, if you put any weight in the back, youre guaranteed to hit the bump stops
Ron Burgundy
01silvapathy wrote:Yup thats the bumpstop. The bumpstop on 4x4parts.com will not work (pretty sure those are designed for truck with leaf sprung axles). Gotta order from a dealership, a stock replacement.
Haven't done any research yet, but any idea how to remove/replace these?
amaff wrote:I "fixed" mine by removing them entirely and installing a pair of AirLift 1000 air bags, and haven't looked back. For more info:
1. That seems like a lot of work/money to fix a damaged bump stop no?
2. Do they make a modified kit for the AC 2" Lift?
fueler wrote:i removed mine completely, never installed anything in their place and my rig has been fine...
Really? Why not just replace them? Couldn't that potentially damge your vehicle if you were to hit a bump or take a dip to fast? I mean, they have to be there for a reason right? ... Right?!
01silvapathy
Yes, they are there for a reason! It keeps your axle from slamming against the truck for one....though I guess the shock would stop it first. But like you said if its there, its a good idea to keep it there! They are relatively easy to take off and put on BUT it can become a complex job. When I did my lift I took them off to get the springs on easier, and the bolt snapped off half way out. So we had to drill out the bolt then tap and die the hole for a new bolt. Its a PITA to get a ratchet up there to unbolt it with the coil on. There is an easier way to do it with the coil off but then gettin a lift coil to fit over that is near impossible.
01silvapathy
But my bumpstop looks different than yours. Kinda looks like yours is on like an extension of sorts. Here is a pic of when I did my lift.
fueler
Car: 2 Nissan's
2 BMW's
cause the bolt that holds the bumpstop on broke off in the unibody frame!!
be careful not to do the same.... i think i was ratcheting it kind of crooked when it broke...
i can probably fix it but its gonna be a pain in the ***..... and honestly i dont notice any difference.... if anything, i probably get more tuck on one side during flex...
01silvapathy
Or if you need to haul or tow anything over some pot holes or dips in the road at speed.....loud noises will be had! My bolts broke off, nothing a few hours with a drill, tap and die couldnt fix!
Ron Burgundy
01silvapathy wrote:But my bumpstop looks different than yours. Kinda looks like yours is on like an extension of sorts. Here is a pic of when I did my lift.
Looks like theres three different types of bump-stops varrying from 1996-2004, 3.3L to 3.5L, and 2WD to 4WD.
"http://www.courtesyparts.com/kb_search_ ... _4800_4804"
I know mines the first one listed on the top left. I would assume yours would be the one on the top right.
01silvapathy
Atleast yours are the cheapest of the bunch LOL
Ron Burgundy
Thats right!
Was pretty pleased with that myself...
Green Pathy
Car: 1996 Nissan Pathfinder SE, 4X4
The link that was provided to the three different types of bumpstops no longer works. Im dealing with this now. my bump stops on my 97 pathfinder are completely rotten. need to replace them all but i dont know what to get. as well as the coil spring insulators. cant find accurate information anywhere.
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
The OE p/n is 55240-0W010. http://www.courtesyparts.com/nissan/pat ... 552400w010
You can buy the Febest version on Amazon for nearly half the OE price. http://www.amazon.com/Febest-Nissan-Bum ... B00C6MTQIW
To remove/install them, you need to remove the springs. The bolt that holds them is an 8mm x 1.25.
The bumpstops in the original post are actually from a Jeep Wrangler. The guy that owns that truck now is on NPORA and he has removed them in lieu of AirLift 1000 bags.
Ron Burgundy
Me?
Hawairish
Oops, or maybe two people have had R50s with Jeep bumpstops :gapteeth:
Green Pathy
the other option is to drop in the red polyurethane bump stops in the middle of the coil spring from 4x4parts http://www.4x4parts.com/i-18915678-coil ... mpers.html
