What is the window antenna in the rear window?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Ok i have this rear window antenna but is it for the radio or the phone that some q45's came with?
and if someone breaks the rear glass will i lose the rear window antenna or will they have glasses at any glass shop with the built in antenna?
Q45tech
The FM system uses two antennae to cover vetical and horizontal polarization ..................many FM stations transmit both polarities however when a signal bounces of a building it inverts polarity.The Bose system listens for the stronger signal whether from glass or rod.
The rear glass is extremely specialized a dealer only item due to complexity and uv coating..........more than $1000.............never seen one broken in 17 years except by bullets
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
ppastos,
Have you considered consolidating your questions into one thread?
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
drftard
Car: 1992 Inifini Q45/ Nissan G50 President
i believe i have 1 also... but my signal for fm radio isn't as strong as it use to be... my rear antenna outside kinda died even though when i turn off the car i hear the motor turning nothing happens to it... just stays up there... but there seems to be a reciever in the interior rear windshield as described... Thanks for the help!
