What is the standard tire diameter for 2008 altima coupe 3.5SE?
All things Altima Coupe.
Khaled
I guess there is an error in my speedometer due to my tires size, that's why I need to know the standard tire diameter, to calculate the speedometer error %
Khaled.
Plastics
Car: 2007 Honda Civic EX, 1999 Dodge Caravan
26.3 inches
Khaled
My tires are 215/55R17 which is almost equal to the standard tire diameter for the A/C!What is the source of error in my speedometer then?
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
Khaled wrote:My tires are 215/55R17 which is almost equal to the standard tire diameter for the A/C!What is the source of error in my speedometer then?
use this tire calculator to find out
http://www.discounttire.com/dtcs/infoTireMath.dos
Khaled
There is about 10% error (more than actual speed) in my speedometer reading. Is this normal?I've checked my tier and it got the same standard diameter for the A/C! Why do I have this error?
Is it possible to reduce it? should I take my A/C to the dealership in order to fix this error?
Khaled.
Modified by Khaled at 10:32 AM 1/18/2009
mikegtr06
Car: 1995 180sx
yep. if the tire size is not the problem call the stealership and they will prolly tell you to bring it in.....
Khaled
yeah I guess it's not a tire issue because I did not change them, they are still stock.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
How do you guys know that your speedo is off? Are you using a GPS to see your actual speed?
Khaled
For me:
1. I passed a speed camera and I was exceeding the speed limit (according to my speedometer reading) by about 10kmp. the camera did not flash. Happened with me many times!
2. I fixed my A/C speed with my friend's IS300 speed (both 160kph). He was going faster than me
3. Finally, I tired my GPS and the actual speed of the GPS was lower by about 10% from the speedometer reading
