what is the size of the projetor from a j30 headlight
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I bought some j30 lights and I want to put "Halos", "Angel eyes" or "Demon eyes" (what ever is easier for you to understand). But before i go taking them apart I want to be sure of the projectors diameter?
brandonjustice93J30
Car: 1993 Infiniti J30
just search around...there's a post on how to do it somewhere on here and it has the dimensions
Infinitiguy19
I did search trust me and nothing turned up.
brandonjustice93J30
gr8scott72
Car: 1994 Infiniti J30t
ppastos wrote:I bought some j30 lights and I want to put "Halos", "Angel eyes" or "Demon eyes" (what ever is easier for you to understand). But before i go taking them apart I want to be sure of the projectors diameter?
You've got the light in your hand, measure it.
driverdriver
Car: NICO's longtime resident Canuck!!!
Look here for the angel eyes modification:
http://www.nicoclub.com/subpag...l#j30
yodawill2000
Car: 94 Infiniti J30
Driver
The angle eye link is blank.Just side banners FYI
Modified by yodawill2000 at 9:11 PM 2/9/2008
driverdriver
Yoda, thanks for pointing that out.
Try it now.
It's working.
yodawill2000
Looks like a fun project.Shame the link to his pics is dead but the description of the procedure spells it out well.Thanks for the link to that section Driver.Never even knew it was there !!!
driverdriver
There are lots of hidden areas on this forum with J30/M30 information. It sjust takes a little curiousity and some clicking.
Infinitiguy19
The headlights on a J30 are not as long as the OEM 1990-1993 Infiniti Q45 headlights. I have never tried to retro fit the projectors from J30 headlights on OEM 1990-1993 Q45 headlights, But I don't see it as being impossible. Obviously it would be harder to make it look OEM.
There are some JDM 1994-1996 Q45 headlights with projectors and "Angel eyes", But they are custom made.
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
the size halos i used was a 80mm for the driving lights and 90mm for the high beams. got them from here: http://www.theretrofitsource.com/produc ... 698b9ec518 I can do a set for you if you are interested.
clemson99
Car: 93 Infiniti J30 Green (daily use)
06 Infiniti M35X Gray (week end)
Hey Shark,
This post is old but I have a 93 Infiniti J30 and been thinking about getting some upgrades done this year. I saw the mods you did on the angel eyes and wanted to know if you are still doing that? If so what would that run? I have a couple of other things I want to do but want to know how feasible it would be to get it done.
JP72
Diy angel eyes are pretty simple.. I can post a quick diy if you can't find good info/ you don't wanna have shark make them for you
clemson99
sure that would be great. send it.
JP72
supplies consist of window blind rods (clear obviously), reflection tape, clear nail polish(dollar store), dremel, drill and bit, electrical tape, heat shrink, wires resister and switch. Preheat oven to 350 and while its preheating cut all your rods in half and remove the tip. Then take measurments of how big your light is and find a round object that size. (I used the lid of the sugar container and a spaghetti jar) then throw one of the rods on a piece of foil in the oven for 4 minutes. Take it out after the four minutes is up and wrap it around your sugar lid. Hold for about 15 seconds until it hardens. Repeat for the rest of your rods. then figure out how you want your halos to look, as in how big the gap is and cut with your dremel what you would like. Then use the dremel to cut little slits all along the front of your halo. Take your drill and drill
into the ends. This is going to be one of the harder steps since your dealing with something so small and a slip of the hand can ruin the hole.( to be extra carefull I drilled a hole I knew was too small, threw the rods in the oven for about two minutes and shoved the led in the hole) Fit your led, and make adjustments. Then take clear nail polish and dab it in your fresh drilled holes. This will keep it strong and allow more light through. Kind of acting like a magnifying glass. put the reftective tape on the back, then its basic wiring and taping from there.
So maybe it wasn't that brief.. lol
JP72
I should probably also add that your first time making them usually doesn't go all that smooth.. so if swimshark is willing to make you some I'd go that route :bigthumb:
JDM_J30_tx
Car: Pearl White 96' Infiniti J30
Why not just by the CCFL Halos on ebay? Order a set of 80's and 90's. Bake lights, mount halos, reseal, wire em up to your parking lights.
swimshark
i can do them if you are really interested.
yodawill2000
I will add that Shark does a GREAT job. :)
clemson99
thanks shark but I decided to go with regular morimoto HID's and they are great. I'm also looking to get my sunroof and interior redone. So I will focus on that for the summer.
