Xero »
https://forums.nicoclub.com/xero-u712.html
Thu Nov 28, 2002 3:56 am
700rpms +/- 50, the FSM says that, there's a scew on the IAA valve, that is how you should adjust it if the increments are small.
But if your is sitting at 1500, you have to do some more stuff,
Here's from the FSM:
1.) Before adjusting idle speed on the engine you must visually check the following items first: air cleaner for being clogged, hoses and ducts for leaks, EGR valve for proper operation, all electrical connectors, gaskets, and the throttle valve and throttle valve switch operation.
2.) Start the engine and warm the engine so it reaches normal operating temperature. The water temperature indicator should be in the middle of the gauge.
3.) Race the engine to 2k-3krpms, a few times under no load and then allow it to return to idle speed.
4.) Connect the tach. according to the instrument manufacturer's directions.
5.) Check the idle speed in the neutral position for both manual and autmatic transmission models. (700rpms for manual)
6.) If the idle speed needs adjusted, you must disconnect the throttle position sensor harness connector.
7.) Adjust idle speed to tune-up specifications(700rpms) by turning the idle adjusting screw. Which is located on the IAA valve block which is attatched to the back of the intake manifold, there's a screw there.
8.) Stop the engine. Connect the throttle sensor harness connector.
9.) Remove the Tach and road test for proper operation
If your car has a tach. you don't need to buy a clip on tach. Just use your in-dash tach.
