Hi,
I have just been reading "how stuff works" and they say that the optimum temp for engine coolant is 93degC for best ignition timing.
Is this the case for the SR? I have an adjustable thermostat for my electric fans along with my Greddy coolant temp sensor. I have it set to 83degC now, but maybe I should have it higher.
In addition, can a turbo that is going bad cause higher than normal engine temps. I am trying to find the reason for a loss in power with more turbo lag and my engine temperature geting higher quicker... ie my cooling fans have to come on more often than before.
thanks
Modified by PhopsonNY at 5:18 PM 4/1/2006
