Nismo_Freak wrote:So your saying that if I use a 2.00 rear end vs. a 5.00 rear end ... when I shift into 2nd from 1st I will be at the same RPM and speed with both rear ends with the same gear ratios. If that where the case then you would benefit not only from improved acceleration but a higher top speed with the 5.00 gear since it will apply more torque in the final overdrive gear and hence accelerate the car to a faster speed.
About the powerband... of course the powerband is not effected. If you read my post CORRECTLY you will notice that I stated that a quicker ratio ... a 4.30 for example would not benefit a KA driven vehicle since the powerband for the KA lies in the midrange. I posted the link of the powerband so he knows what kind of powerband the KA has, to illustrate my point of why he sound keep the stock gears. LS1s however have exceptional top end and benefit from the move up in gear ratios.
Read my first post in this thread. I never said it wouldn't affect the speed. In fact, I said quite the contrary.
As far as the powerband, how exactly does changing the rear gear affect the powerband? The rear end does not care where the powerband is. If you want to only use just the midrange, shift early. But quite frankly, assuming you have traction and you use the same shift point in each gear(Engine RPM), you will accelerate quicker from a standstill to any speed or distance. I am taking out the time it takes to shift for this example though.
It all comes down to how much torque makes it to the ground. The more torque you can put down, the faster the car should be.
Furthermore, you're theory about staying in the midrange is quite flawed. I mapped out the dyno chart with the 240sx transmission gearing and shifting at 6000 in every gear gives you the most torque at almost all times. It may actually benefit you to rev even higher, but without the figures from over 6000 RPM, I can't tell for sure.
Here's my analysis (Keep in mind some of the numbers are estimated from the graph but should be close enough to prove my point):
Gear__Ratio_E RPM___E Torque___D RPM__D Torque
1____3.321__6000____108______1806___3582____1.902__3436____135______1806___256____________6000____108_____3154____2053____1.308__4126____142______3154___185____________6000____108_____4587____1414____1.000__4587____141______4587___141____________6000____108_____6000____1085____0.759__4554____140______6000___106
E = EngineD = Driveshaft
(Okay, that's as good as it gets)
This chart (sorry I can't make it prettier) depicts the change in torque at each shift. Between 1st and second, you see a huge drop in torque at the driveshaft. Over 100 lb-ft. Multiply that by a 4.083 gear and that's a 400 lb-ft difference. Between 2nd and 3rd, its about 20 lb-ft. That's still about a 80 lb-ft difference through a 4.083 rear gear. The shift from 3rd to 4th is very good at 6000 RPM. The Shift to 5th isn't too bad either. The first 2 gears could benefit from going past 6000 RPM to some extent. On this KA, you'll may actually hit redline before you see an optimal shiftpoint in 1st. Point being that shifting earlier would make you miss out on some of the torque available through multiplication. The rear gear would then just take the torque and RPM's from the Driveshaft and alter those. But the rear gear can not change the torque measured at the driveshaft.
