What is the plug wire arrangement on a NAPZ-2.4?
robii
i need help with how the wires run from distributor to the plugs on a 1987 nissan pick up with the z-24 engine.8 wires thank you
Red coupe
Car: 92 Nissan 240sx Coupe
http://wiki.answers.com/Q/What...ngine
Some info there... Didn't really go through it to make sure it answers your question.
Googling Nissan Z-24 ignition wires actually seemed like it had quite a few results.
Axel Grungy
Car: 2001 G20 5spd
moved to trucks forum
xckid
Car: 2004 Chevy Blazer ZR2
welcome to nico...and if you have your owners manual it should say...that or if their certain lengths...see which reaches where to where
lmao i thought i went crazy..i was like wtf....how did i post in the truck forums hahahha thought this was gen chat
robii
i need help with how the wires runfrom the distributor out to the plugs on a 1987 nissan pick up z-24 engine 8 wires thank you
Q451990
Did the link above not help?
Heath
Red coupe
robii wrote:i need help with how the wires runfrom the distributor out to the plugs on a 1987 nissan pick up z-24 engine 8 wires thank you
Uhhh yeah... that's what firing order is... what order the cylinders are fired in...
thats the order the wires need to be hooked up to the dizzy in...
Q451990
I guess the only question that hasn't been answered here is which plug on each cylinder is for the intake side, and which one is for the exhaust. It's been a long time since I've looked at a Z-24 and I never worked on it... it was my dad's for a short time. So if anyone can answer that there shouldn't be anymore questions on this as long as the distributor cap and wires are marked I1, I2, I3, I4, E1, E2, etc.
Heath
Red coupe
Q451990 wrote:I guess the only question that hasn't been answered here is which plug on each cylinder is for the intake side, and which one is for the exhaust. It's been a long time since I've looked at a Z-24 and I never worked on it... it was my dad's for a short time. So if anyone can answer that there shouldn't be anymore questions on this as long as the distributor cap and wires are marked I1, I2, I3, I4, E1, E2, etc.
Heath
The plug on the intake side is the intake plug, the side on the exhaust side is the exhaust plug....Quote »The Z24 engine has 8 firing ports; four on the intake manifold side of the engine,four on the exhaust side.[/quote]So I1 would go to the plug on the same side as the intake manifold of cylinder 1...
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
This is the firing order and wire location you need. If you are looking for a real image of how to place the wires I can't help you but this schematic from the Nissan manual should help
Q451990
Red coupe wrote: The plug on the intake side is the intake plug, the side on the exhaust side is the exhaust plug....
Gotcha... for some reason I remember them being on the same side one above the other, but like I said - it's been a long time and I never actually worked on it...
Heath
