what is the name / part number of this part ?
infamousbboy
Car: 1991 Nissan 240SX fastback
nobody knows what this part is called or what the part number is and that is making it difficult to order.
it connects to the distributor on a 1991 nissan 240sx and has four wires that go to it. ive called it a distributor connector, distributor wire harness, nobody knows or can find it... can anyone help find one or provide a part number? i need the actual harness with the connector . thanks.
inshje01
Car: 1989 Nissan 240SX Fastback
I think this is what you are looking for:
It calls it the throttle harness sensor connector. It being the repair guide that you can find on AutoZone's website.
zer0c123
Car: 1993 Nissan 240SX Hatch
You will have to buy the whole engine wiring harness just for that connector, which is about $300. The cheaper route is to get that connector from a junk yard or byt the engine harness from someone in the classifieds, and just cut and splice the wires together. Then soldier the wire up and seal it with heat shrink wrap.
