Does the top mount manifold create a situation where your turbo water feed line is now the highest point in the cooling system? If so, how do you intend on bleeding the air from that line?StricNyne wrote:for feed the best way, is to use the oem feed on block on exh side obviously, for returb plumb it into the heater core hoses, i am getting weldable an6 on a pipe i am making to do it for my setup
this is how mine was plumbed on my previous setup and it worked fineStricNyne wrote:for feed the best way, is to use the oem feed on block on exh side obviously, for returb plumb it into the heater core hoses, i am getting weldable an6 on a pipe i am making to do it for my setup
