Ryan Heo »
https://forums.nicoclub.com/ryan-heo-u67107.html
Sun Nov 25, 2007 7:28 am
When the engine temp. gauge is on normal degree, the hard staring problem came up mostly. In the mornig when the engine is cold, the start is almost good as normal. But after sitting 5~10min., it need a long crank time. Also when the engine is hot, the start is good to 1 out of 20.
Nobody has the solution for the hard starting problem. I wouldl like to tell about the history of repair.
My I30 had the starting problem before I bought.Only what I knew about the problem, the problem was started after the transmission was rebuilt. Right after the A/T was rebuilt, the car won't started at all. So it was repaired to the problem on the another shop. It was the labor description at that time.
CRANKS BUT WILL NOT START ------------ $192HAS SPARK AND INJECTOR PULSE. HAS GOOD FUEL PRESSURE. INSPECTED SPARK PLUGS AND FOUND PLUGS GAS FOULED.REPLACED SPARK PLUGS WIHT O/E STYLE.CARBON BUILD UP CAUSING HARD START WHEN COLD.NEEDS TO CLEAN MOUNTING SURFACE BETWEEN ENGINE AND TRANSMISSION. REROUTE GROUND CABLE TO THE STATER BOLT.
CLEAN MATING SURFACE BETWEEN TRANSMISSION AND ENGINE.INSTALLED GROUND CABLE TO THE STARTER BOLT. AFTER CLEANING VEHICLE NOW STARTS AND RUNS. -------------- $352
When the repair was done, the start was good like normal. However after one month, it was getting worse. Like three times every 10 times was hard to start.
On two months later I've infiniti dealership and import car specialist but they just told me that
1.the error code P1320 even though the car haven't show up the CEL. (I don't know how did they get the code.) So it might be needed to replace all of the ignition coils -$950. 2. Also the ECU could be malfunctioned. It should go to dealership. 3. The carbon could be accumulated inside the engine.
After that, I replaced the ignition coils and crankshaft sensor but nothing. I spent about $1000 to try to fix the problem. But I'm missing now.
The list of parts which were replaced.1. an alternator2. a starter3. spark plugs4. a PCV valve5. a coolant temperature sensor6. an ignition switch7. a fuel pump relay8. a knock sensor9. a fuel filter10. a valve cover gasket11. spark plug tube seals12. a battery13. an air filter14. oxygen sensors15. five ignition coils (one is left)16. cleaned IAV valve and throttle body17. cleaned the engine grounds18. put the fuel system cleaner
I found someguys who have the similar problem and fix that. They made new groud wires to fix the problem. So I tried that way but nothing happens to me. Unfornately the solution is for a M/T model not a A/T. I'm just full time student with a small budget to fix a car.
If someone know about the problem and guaranty to fix a solution, I would like to go to get rid of the problem anywhere. I want to know how to do it and inform to all other guys who have the same problem.
Thanks.
