slybydesignq45t »
https://forums.nicoclub.com/slybydesignq45t-u98436.html
Thu Oct 30, 2008 6:00 am
Last night I started working on pulling my ECU. I went to my trunk and got my mechanics manual and noticed an area where the jack and jumper cables are. I pulled the black plastic piece and saw the car still had the original jumper cables and jack. So I pulled the jack out, but when I did so I saw a long thing tube thing loose. I fished around an bit and saw what seemed to be where it went by the so I just popped it back or what I think was back. I could not find anything in the manual for this tube like thing. I was only left to assume it was a drain tube to direct any rain or water down, sorta like a duck. I hope I put it back in the right place. It had no funny smell nor a hist.
The more I work with this car the more I find how complicated it is. Also I notice the passenger side of my center by the shifter is loose. It looks as if the glue is weak. I want to take that apart and fix it. Its minimal but I like a flush look. I was wondering if I can fix it, or do I need a straight replacement?
