qsiguy »
https://forums.nicoclub.com/qsiguy-u27015.html
Sat Feb 09, 2008 6:17 pm
The '93 ECU is an easy mod, especially if you only want a single program. I've got a stage 1 program for a '93 ECU. Wes should chime in soon, maybe he will do a single program mod for you. All the NICO ECU's are going through Wes (Elwesso) now.
Not sure about a "lower octane" map tho. If you really want to use low octane fuel and have a stock ECU just use it. It's not going to be any better for the engine if you change the ECU. Maybe if you just back off the timing a little it would like it better. If you ignore the knock sensors you are asking for trouble. The performance maps do that but if you do that when wanting to use low octane fuel you could do some serious damage.
What do you mean by "GM"
