So then caster is looking at those same lines but from the side of the car? Ok, but how do people change that then? seems like a pretty set thing to me. Can someone quickly remind me what kind of effect caster has on handling again?
EDIT: actually, lets keep chet happy. found this on wikipedia (a great site if you ask me)
http://en.wikipedia.org/wiki/CasterQuote »Excessive caster angle will make the steering heavier and less responsive, although, in racing, large caster angles are used to improve camber gain in cornering.[/quote]But what I still don't know is, does lowering the car effect caster and what is the stock caster angle on a 240? Also, if you don't mind taking a quick look at that article Chet, or anyone else, they talk about the mechanical trail and how setting it is independant of setting castor. I am not sure how this would work so some clarification would be great. They also say that trail adds more feel to the steering but I am not sure if they mean a longer trail or a shorter trail adds more feel.
Modified by vvaffle at 1:17 PM 10/13/2005
