What Is The Fluid Level?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
VIsa Versa
Car: 2008 Nissan Versa Sedan
We have a 2008 Versa S with the regular 4 speed automatic. I want to change the ATF fluid but I can't find the capacity level listed any where in the owners manuel. Can you please tell me how many quarts of ATF I need to use. Thanks.
biggie
Manual says to fill until it reaches the proper level on the dipstick, so may have to be trial and error.
I would guess its going to be somewhere between 2 and 3 quarts. Most AT are around 3 qts I believe, but not sure if that is with/without filling up the cooler.
I'd start off with 2 and then see where it is on the dipstick.
Hopefully someone knows the exact quantity on here or you can call the dealer and ask.
NODES
Car: 2007 Nissan Versa SL (Blue)
Remember there will be a bit left in the torque converter.
what is your mileage on the car that you have to replace the fluid?
alonsorules8
Car: 2008 Nissan Versa SL HB
It is recommended to replace the A/T fluid at 30k miles according to your owners manual.
The service manual states there is 8 3/8 qt of A/T fluid in the transmission and recommends using Genuine NISSAN Matic “D” ATF (ContinentalU.S. and Alaska) or Canada NISSAN Automatic Transmission Fluid *2.
NODES
alonsorules8 wrote:It is recommended to replace the A/T fluid at 30k miles according to your owners manual.
wow 30K that is quite early.
alonsorules8
Not for regular A/T that is the average mileage interval for most auto makers including Chevy, Ford, Honda Nissan, and Kia.
When I was working for GM if you went over 75000 miles and never had the transmission fluid flushed we would not do a transmission service due to the risk of having the seals leak.
Now if you own a CVT the recommended interval change is at 60,000 miles.
NODES
alonsorules8 wrote:Not for regular A/T that is the average mileage interval for most auto makers including Chevy, Ford, Honda Nissan, and Kia.
those sound like more reasonable numbers.
alonsorules8
The A/T fluid thins as it ages and that is why Nissan recommends it being replaced every 30k its down to the type of trans fluid the transmission needs.
Just like Nissan recommends the coolant being flush every 30k as well.
It a recommendation and up to you if you want the longevity of you transmission to be there and not burned up at 175K miles or still going strong at 200k.
As a mechanic, and if I had the 4 speed auto trans every 30k then fluid would be flushed as well as the coolant system.
As I stated earlier due to the different fluid type for the CVT the recommendation from Nissan is 60k and that is when I plan on having my CVT serviced. as well as every 60k after that.
br4dysays
Car: 06 Nissan Altima SE-R
i have a 4spd auto & have about 51k on it now.
flushed coolant & trans @32k
no issues, plan on doing it again @ 60k-ish.
NODES
br4dysays wrote:i have a 4spd auto & have about 51k on it now.
few more miles and I guess I will flush my coolant out then.
Return to “Versa Technical Discussions”
