What is the final gear ratio in the RB25 diff?
74260zt
Car: rb26powered early 74 260z car
I'm just about ready to hook up my set up, which is a RB26 to a RB25det trans, and I already have a 88 Shirro Edition VLSD with a 3:70 diff in my 260Z.
My main concern is will this 3:7 Diff be OK for the RB power band? I hear the RB's have a higher RPM range than the Zcar L6 motor...
Can anyone tell me what the OEM Diff ratio is for the RB25det GTS-T??
thanksjoelMY CURRENT MOTOR AUCTION
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
PROJECTRB240SX
RB20 IS A 4.11240SX IS A 4.08300ZX IS A 4.11300ZXTT AND RB26 IS A 3.96
74260zt
Thanks! So...... it looks as if I'll be a bit on the bogging end of the RPM scale... :(
mambastu
R33 GTS-T manual is actually a 4.1 - I've checked this myself by counting the teeth
Wykid 240
SO what gear should you run with a RB25?
mambastu
Wykid 240 wrote:SO what gear should you run with a RB25?
For general use I'd stick with the Skyline gearing. Its pretty good.
74260zt
Looks like I'll be stretching out each gear alittle longer with my 3:7 diff.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
PROJECTRB240SX wrote:RB20 IS A 4.11240SX IS A 4.08300ZX IS A 4.11300ZXTT AND RB26 IS A 3.96
actually, the rb26 uses a 4.11 rear [r32 does anyway]
and the Z32TT uses a 3.69
if you want to go taller, the Q45 uses a 3.58 diff.
PROJECTRB240SX
what color is the rb25det speedo sensor?what color is the rb20det speedo sensor?what color is the 300zx speedo sensor?what color is the rb26dett speedo sensor?
PROJECTRB240SX
YELLOW is the 16 tooth for the 3.36
BLACK is the 17 tooth for the 3.54
BLUE is the 18 tooth for the 3.70
WHITE is the 19 tooth for the 3.90
RED is the 20 tooth for the 4.11
PURPLE is the 21 tooth for the 4.38
PROJECTRB240SX
the rb25det I had, had a Purple Speedo sensor.The 300zxtt transmission my friend has, has a white sensor.
on the rb26dett you are right.... It should have read r34 6spd rb26 has a 3.96.
PROJECTRB240SX
Then you have to factor in wheel size to get the true final drive.
mambastu
PROJECTRB240SX wrote:the rb25det I had, had a Purple Speedo sensor.The 300zxtt transmission my friend has, has a white sensor.
Thats odd, my RB25DET has the red 20 tooth speedo sensor :confused:
Did you buy a half cut for your RB25 or a whole car ? I believe some of the GTS-T's came with some sort of electronic diff. I wonder if yours was one of those maybe ?
PROJECTRB240SX
IT WAS A MOTORSET.... SO YEAH ANYTHING COULD HAVE HAPPEND. I ONLY HAD THE MOTOR FOR A FEW DAYS.... BEFORE IT TRANSFERED HANDS.
IvoryJ30t
the R34 GTR is 3.545
74260zt
IvoryJ30t wrote:the R34 GTR is 3.545
yes, but I belive the R34 has different gear ratios in the trans though... that will affect the final RPMs, and thats what I'm trying to determine, if using a RB25det trans with a 3:7 diff, will be in the optimum rev range....
Imissmyturbo
Car: Car's, Turbo's, sking
I have found the 4:11 Diff to be a bit too short for the RB25 with Stock 240sx tires. I ran a 13.8 @ 104 and was almost at redline in 4th gear. I find when racing other cars on hyw that I have to back out before anyone else since 5th gear isn't a good racing gear. With a 3.9 or taller you will see a higher top speed in each gear. The gear ratio from 1-4th on the RB 25 transmission is pretty close so I think you can get away with running a taller final drive.
BoostFab
Car: S13cp, S13fb, S14z
i'm thinking about using a J30 Diff for the RB20....iirc...it's 3.9~ish??? you guys know J30's top speed?
IvoryJ30t
yes, the r34 6 speed has shorter gears in the trans, made up for by the 3.545 rear.
the J30 uses a 3.916 rear.
if you give me a tire size, transmission, rear ratio, and redline, ill tell you the theoretical top speed.
