I can also add these questions.
Does all the Pathfinder R50 have a Transfer Case ?
Is there a tutorial with a picture on how to change the Transfer Fluid ?
Do we really have to change the Differential Carrier Gear Oil ?
Is there a tutorial with picture on how to change the Differential Carrier Gear Oil ?
I have read that some had problem, because they were not able to put as much oil as they drained...
About ATF, thank you so much for the tutorial and the pictures !!!! I'm still thinking about opening the pan and changing the filter....
One question, we have a description about how to do the flush here is the description:
"1. Disconnect the transmission cooler return line and secure it in a collection bucket such as a clear gallon milk jug. This will be the hose on the passenger side of the vehicle; disconnect the end leading towards the transmission.
2. Have a helper start the car while you watch the bucket - once it's half full (2 quarts), yell for the helper to stop the engine.
3. Add 2 quarts of ATF through the transmission dipstick.
4. Drain collection jug into larger jug (i.e. a Disposoil - these only hold 10 quarts though in my experience, so have something else to hold the last 5 quarts).
5. Repeat steps 2-4 until you're out of ATF.
6. Check fluid for proper level (see the next question and answer for details), and recycle the old ATF. Any place that takes used oil will likely recycle ATF.
If we do the flush method, it means, if I understood well, that we are not draining the ATF through the drain plug, am I correct ?
Wehn we start the engine , do we leave the gear on Parking position ?
Would it be possible to have a picture of the Transmission Cooler return line ?
And lastly, we have an advice to install a Magnefine in-line transmission filter on the transmission cooler return line, where and how exatly do we install it ? Any picture available ?
I know I'm a little annoying by all my questions and I'm not at all a mechanic...
I'm very very thankful to all of you for your precious help and patience !!!!
THANK YOU !!!!!
Philippe
