autotech43 »
https://forums.nicoclub.com/autotech43-u4010.html
Mon Nov 10, 2003 7:16 am
Szhosain, we get the 9E000 filters for the M-45. Now there were some folks concern on some 2001 I30's regarding some of the engines had a 65F00 filter and others had the 9E000 filter. The 65F00 filter is an inch or so shorter, but you could use either filter with no problem. From the factory, the engines with the oil cooler had the short filter, and ones without the cooler took the longer (9E000) filter. There are no differences at all regarding the filter characteristics. I spoke with Infiniti engineering regarding some customers concern regarding the filter, there reply was that the filter change was in the middle of the production year, and some of the engines at the factory were installed persay a week early, or late, so the production date may show the engine to have either filter. All Infiniti filters have the check valve, and filter the engine oil according to specifications. I've been with Infiniti/Nissan for many years, and they change part numbers like clock work on numerous items. Occasionally, if the item in question of being a possible updated design, may occur when you have supercession numbers from say an 15208-9E000 to a 15208-9E001 and so on, but doesn't always mean a design change. Rule of thumb, change your oil and filter every 3,750 miles and your engine will thank-you in the long run!
