I run a 67mm also (when my car runs) Whats the exhaust A/R? Mine is .68. I was seeing full boost right around (14 psi) 5 grand-5200. Maybe my cams, and 87mm bore and 26 crank played a roll more than I thought. Still awesome numbers for a little 240.RBTALLY wrote:yes stock cams... as for the rpm limit that motor has not been started in 3 years so I was a little easy on it ... once the nitrous is on in a few days I will put it back on the dyno and spin it on up... turbo is a little 67mm compared to the 114mm on my outlaw car.
Riggs is also running a Billet 67mm now.DrifterProdigy85 wrote:Shocker, your 67mm shouldnt be that laggy on a 2.5L. Is this on a 4th gear road pull or is this where your peak tq is made on a dynojet? With the 2.small i was logging 24psi @ 5600rpm and peak tq was showing at 6000rpm on the dyno. I think Riggs (blue underground motorsports RB25) was getting 34psi @ 5500rpm with his 67mm.
Lol powerglide is the s*** for drag racing. Is it pretty doggy though just cruising around?RBTALLY wrote:if you were talking about my car it has automatic trans in it with only 2 gears....
The new billet 67 seems pretty badass. Just about everyone is doing 800+whp on them with a proper setup. They still spool the same or a little slower than the normal 67mm though. Its still a cast turbine and its slightly larger turbine wheel from what ive read. They pack one hell of a punch though for the size.Shocker wrote:
As for my car we never got to full add the timing we wnated in before we ran into engine/ecu issues that ended our runs and my year for my car. Search topics made by me you will see my thread.
4th gear pulls on a mustang dyno. From what I've seen the boost should come on harder if it had been raised a lot higher. I'll get back to you on the matter hopefully next spring. lol
On what engine ? Rb25 ? Thats a flat out lie if I ever heard one. I'm learning the hard way what an rb can do. 8k into an engine and i'm @ 500whp.... I have been told the blocks rip in half around 1000hp by two rep tuners???abubika345 wrote:There is a guy around my way running 9sec. 772hp on pump 956hp on c16 stock bottom end. I was pretty impressed. Couldnt believe that he also drove the car to the track....
I would love to see proof of an RB25 with more than 800whp in the US. stock or modified. Even 700whp, heck even >650whp.Beanstalk wrote:
I will be around 850whp by 2010.... all I need is a reliable maf(s) to get me there..... Im built, got fuel, goooooot turbo, just need an AEM EMS... or a maf????eh? wrote: I would love to see proof of an RB25 with more than 800whp in the US. stock or modified. Even 700whp, heck even >650whp.
..... Wow why do guys got to lie ???? I'm not sayin you ....abu are lying but that is just not happening and if your dumb enough to believe it thenabubika345 wrote:There is a guy around my way running 9sec. 772hp on pump 956hp on c16 stock bottom end. I was pretty impressed. Couldnt believe that he also drove the car to the track....
I think I can put down 650 in a few weeks even through a auto transmition. still a stock motor... I wish someone would buy this thing so I would quit spending $ on it.eh? wrote: I would love to see proof of an RB25 with more than 800whp in the US. stock or modified. Even 700whp, heck even >650whp.
lol just get a hobby that is more expensive than a rb. Mine is musicRBTALLY wrote:
