What is the charcoal filter element?
Joselito
I'm a noob and am trying to figure out what the charcoal filter element and when it needs to be replaced, I own a 90 240sx.
Silvia007
Car: 93 Nissan 240SX SE Fastback
no clue! Where is it located?
nissanrcer240
Car: 90 Nissan 240SX SR20DET
Quote »charcoal filter element [/quote]
i thought it was called the charcoal canister element...i had asked a question reguarding this part a couple months ago but i dont think it said exactly what it is..
ride4lame
The charcool element is a canister located to the right of the radiator. It is part of the emmisions system. I am not positive, but it does something with relieving pressure in the fuel lines i think. I have not a clue when u would need to replace it.
BuudWeizErr
Pressure builds up in your gas tank. What that does is there is a line that runs forward into your engine bay, across thefirewall and up to the front support, then plugs into the carbon canister. Then there is a vaccum that runs to your throttle body because those fumes are damaging to the environment, and having the intake putting a vaccum on the carbon canister helps promote flow to the canister and I imagine it burns off what it can.
I took mine off. Screw emissions.
Mayhem_J30
Car: Ummm...My Car
it has activated carbon in the canister that i believe filters impurities out of the evaperated fuel fumes from the fuel tank and then routes them to be burned through the intake plenum.
RYNO_s13
Car: Kickboxing, driving like I stole it.
BuudWeizErr wins the prize. It's called the Fuel Evaporation Control. It also causes a minor increase in MPG by helping to burn fumes that otherwise would have been wasted.
Mayhem_J30
Car: Ummm...My Car
RYNO_s13 wrote:fumes that otherwise would have been wasted.
don't forget that they also would have polluted the atmosphere...the real purpose behind the EGR.
240_Keyy
Car: '90 240 Fastback
budweizerr, any chance you can put detailed info on bypassing this mofo up here? mine is cracked and leaks like crazy and it is really pissin me off...
BuudWeizErr
Yes. Undo one screw holding it in place. Unhook hose on bottom of canister. Remove canister. Throw canister as far as you possibly can. Flex muscles. Consider working out more. Remove and cap vaccum line that goes to the throttle body. Let the line that comes from the firewall and the big line that was under the canister vent to atmosphere. Drink a beer while admiring how "mechanically-inclined" you are. Call it a day (you've worked hard today!).
Problem solved.
240_Keyy
yeah, but gas pours out of mine. I cant just let it sit there like a limp, leaky peepee...
RYNO_s13
Mayhem_J30 wrote:don't forget that they also would have polluted the atmosphere...the real purpose behind the EGR.
Atmosphere, Schmatmosphere. So we're a few peguins short. And?
Mayhem_J30
Car: Ummm...My Car
RYNO_s13 wrote:Atmosphere, Schmatmosphere. So we're a few peguins short. And?
just continuing the discussion of what the EGR is and does. :pface
wanabe240esx
240_Keyy wrote:yeah, but gas pours out of mine. I cant just let it sit there like a limp, leaky peepee...
then you've got the wrong hose, just put a cap on it, THEN drink the beer
240_Keyy
oh ok, then it is cool to cap off the one that leaks?
wanabe240esx
does the engine run whlie your "peepee" leaks, if so its just full of gas, try to empty most of it out be4 you cap it off
ride4lame
do bypassing this actually give you more power? it doesn't seem like it would, and there is no reason to pollute for no reason
240_Keyy
yeah, the engine still runs fine and everything, gas just pours out of the damned thing. I don't think it gives any more power and I am from Texas so I can give two poops about the environment :D
