What is the brake bleeding sequence on a 2009 Rogue?
Scooterboots
Car: ???
Sorry for the garbage post, I have to replace the calipers on the wife's Rogue. I was looking for confirmation of the bleeding sequence, but haven't found a concrete answer.
Doesn't say anything in her manual about the sequence.
Again, sorry for the garbage post, thanks.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's no set sequence on an '09. You should generally do front first if the master or ABS lines have been loose, the lines are shorter and you'll get pressure faster for bleeding the rears. For calipers just go around the car. Don't press the pedal flat to the floor when bleeding, go only about 3/4. If there's a "corrosion ring" inside the master bore, pressing flat may rip the cups and you'll end up with a bypassing master.
Return to “Rogue Forum”
