What is the boost limiter set at on stock CA ecu?
JDMSIL80
What is the maxium psi you can boost with stock CA ecu until it cuts out?
Thanks!
rico05
Car: 1992 RMS13 w/ CA18DET
I've heard of boost cut hitting anywhere from 11-15psi. It is detrmined by MAF airflow readings.
JDMSIL80
I was running GT28R with stock MAF, it cutted me out at 7psi.
Does it make sense to you?
CA19DET
yes the GT28R flows more lbs/min so the afm will cut at lower boost..
rico05
Oops!! I should have said 11-15psi on a T22/25. My bad!! I do not know the CFM that will trip the cut, sorry!
