What is the best way to cover up the license plate holes?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
williamk10
Car: '07 Nissan Versa SL
For the Versa's with front license plate mounts, what is the best way to cover up the holes left from the mount? I'd like to remove the mounting bracket and place the license plate somewhere else but the 2 holes left by the license plate mount are quite unsightly
biggie
This thread may get lost in the move going on. But for my G I'm going with plastic/nylon plugs and using touch up paint and spray clear coat to match them to the car.
Quite a few have used this method. For the plugs just go to a hardware store and see what you can find.
williamk10
biggie wrote:This thread may get lost in the move going on. But for my G I'm going with plastic/nylon plugs and using touch up paint and spray clear coat to match them to the car.
thanks, i'll look into that
williamk10
I actually found this write up, i think i'll try it
http://www.instructables.com/i...in-y/
Return to “Versa Technical Discussions”
