What is the best EMS
drifterhype
Car: Nissan RPS13
What is the best computer for my car, i got a 90 S13 with a SR20DET swap?
nametakennow
Car: '06 MINI Cooper S
You're in the wrong section. This is the FWD SR section.
That's a really general section that will cause you to get flamed, fyi. I'd try searching.
nismofly
Car: 89 Nissan 240SX Hatch
haltech e11v2
hope youve got $2500 + tuning money laying around
karmakaze
Car: 98 240sx SE
drifterhype wrote:What is the best computer for my car, i got a 90 S13 with a SR20DET swap?
dude, get a Dell.
Rosco
Car: 91' SR'ed Hatch
I hear YourMOM is pretty good....
sr20goofus
MOTEC or Tec 3/Tec GT
both are the best out there, bottom line. You will have to buy new sensores and make your own engine harness, but itll have the most accurate tunability and most user friendly interfaces.
i no longer recommend teh AEM EMS to people as mine had issues at one point in time, now they have recalled all the units i believe.
karmakaze
Car: 98 240sx SE
nismofly wrote:haltech e11v2
the Hal 9000 is even better.
nismofly
i havent looked at standalones in a while so i guess ive lost touch, i hadnt even heard of that one
im required to run a retuned stock ecu in the race class im building my car for
sr20goofus
nismofly wrote:i havent looked at standalones in a while so i guess ive lost touch, i hadnt even heard of that one
retuned stock ECU, your options are very limited. What race class are you building your car for?
nismofly
im going to at least start off running the car in SCCA prepped for ITA specs, then running the car in ITA trim in NASA PTD
yeah you cant do much at all, but i really think itll be a good level to start off at, and my wallet will like me that much more for it...as much as id like to be running ST with you and a couple other east coast people
sr20goofus
itll be awhile before i start racing, even tho im doing whatever i can to stay in PTA that way i can be more competative instead of always needing more power. I just need to keep power around 270-300 and not lighten the car much more and i should be good.
I plan on being a NASA instructor next year, im doing the clinic at VIR in march, its one step closer to me getting MUCH more track time for cheap so i can determine if racing is a financial possibility. (tires and brakes more than anything)
nismofly
of course i say that and the new 2008 GCR comes out and says this
6. The engine management computer may be altered orreplaced. A throttle position sensor and its wiring maybe added or replaced. A MAP sensor and its wiring maybe added. Other existing sensors, excluding the stock airmetering device, may be substituted for equivalent units.
7. Wires and connectors in the engine wiring harness may bemodified or replaced.
Initial_R90
Car: 2003 Zo6 Corvette RIP BLOWN up on the dyno
2003 Evo VIII
Apexi power FC base map is good for stock boost they also sell a boost controller kit so you can manange boost trew it also i use Utec on my Z no problems have a Boost controller kit for the Power fc for a redtop if you coose that path let me know
sr20goofus
the only issue with PFC is that you HAVE to use either their commander, of buy the Datalogit stuff which costs an arm and a leg. not easy to do tuning with laptop.
Initial_R90
2003 Evo VIII
PFC is 699 with commander from JPS or RHD Japan
sr20goofus
i know you can get the PFC cheap, but not the laptop tuning hardware.
whatever you do buy, be sure to get it with a warrenty, electronics are never fun when something goes wrong.
nwmrkt
Car: S13
with the power fc...if i buy the commander also do i need the datalogit?
sr20goofus
datalogit is only for laptop tuning, usse different software and everything.
commander comes with PFC no matter wha i thought.
BEST1TUNING.COM
What plans do you have for the motor as far as mods, power and use? A stock ECU tune goes a LONG way before it can no longer handle the demands of the application.
