what is the best clutch/flywheel set up for a b15 se-r spec v?
nismo2K2
Car: 2012 Versa Sedan
hey guys! i am currently shopping for a good reliable clutch and flywheel setup for my 2002 se-r spec v. the car is my daily driver and i just want to get a good clutch and flywheel that are better than my stock setup and isn't a pain in the *** to use. i would appreciate it if you guys could give any ideas that you may have! thanks!
nametakennow
Car: '06 MINI Cooper S
No point in upgrading unless you're making more power. Any higher performance package is going to be more of a pain in the leg.
A kevlar disc on the stock pressure plate would hold up better without being rougher on the leg or engagement, though. Try Unorthodox Racing, ACT, Clutchmasters, and NICO sponsor Spec.
nismo2K2
i will be making more power. i just order my nismo header and cat-back exhaust, as well as an underfrive pulley. i plan on getting nismo cams and jwt valvetrain. thanks for the advice!
nametakennow
Still not enough power to need a heavy duty pressure plate or a different disc face than what I mentioned.
