Thanks for your sympathy. It will be a while before I begin building. Trying to get the funds together, shop different tuners and decide on the right package. Yes, the kit makes it a totally different car. Just be careful to keep the boost low and around 380whp. Don't be tempted to go higher or you'll be really increasing the risk of engine failure. Good luck and enjoy!Mr. Me Too wrote:sorry about your motor, Brian. you can only inprove from here, which is always a good thing. well, that just about seals the deal. thanx brian, obviously if you are recommending APS after a blown motor the product must be good, which is what keep reading. well, good luck with the new setup.. I got some odering to do....
IIRC the optional warranty you can purchase covers the engine for 3 years/36,000 miles. Stillen's website implies the same, but of course, you'll have to refer to the actual warranty contract for details.Q45tech wrote:Stillen sells a warranty that protects you against their supplied equipment failure not your equipment [engine, transmission etc.].
thanks for the info. now im guessing that this is on stock internals. what if you were to build up the internals and then boost it? would it have the same effect or would it give it better life.Q45tech wrote:The question one should ask is how much degradation in engine transmission and other power train component life will any power increase create!
Doubling the power may decrease lile from 300,000 miles to MINUTES!
Normally engineers use a 30% power reserve [derating] to allow up to 300,000 miles. [Make sure 95% achieve 100,000 miles with per spec maintenance [90 day oil changes].
6PSI is 20.7/14.7 = ~41% higher peak pressure and thus would decrease the engine life down to 50-100k depending upon the number of WOT applications. Total number of minutes at that pressure.
The transmission is rated [AT] 333 lb/ft so expect a decrease in the 100,000 shift life.
One cannot increase oem power by much and expect oem reliability.
Even NASCAR cannot double the engine power and get much over 3 hour engine life.
The trick to getting the best of both worlds is to decrease the max rpm as you increase boost. LOWER THE REDLINE by a third of the boost percent:
6psi boost =40% reduced redline by 14% [6900 down to 5950-6000rpm PEAK] and you can probably double engine life.
Not to start an argument or to say that this post is wrong but I do not understand how a car's transmision type would affect what kind of forced induction kit could be matted to a cars engine. A turbo charger cant tell the difference between automatic and manual transmisions. That makes absolutely no sense at all. The twin turbo kit can be installed just as well to an automatic as it can to a manual gear box. Also there is no such thing as a "bolt on" Turbo kit for any car unless the engine came with a turbo already on it.Nick240sx wrote:Stillen has a few setups and they are a top name brand, good quality and products. is your G the 6mt or is it automatic? if its automatic stillen only has superchargers for it. if its 6mt there are only TT setups available. i was trying to decide what i want to do with my 6MT G35C this fall. thats what i have come across. ill have to take a look at the APS product.
