what is that sound coming from my door.
greendusk
Car: 1990 300zx TT Pearl Glow (5 Speed now after swap)
1990 300zx NA Black Auto(Sold)
1990 300zx NA Purple 5 Speed(Engine Washed /Sold)
2001 Stratus (Scrapped)
So my passengers door when the key is turned to on makes a buzzing sound it seems to coming from the front half of the door.
Also something odd stated happening the other day when I had the t-tops in the trunk the warning light for the hatch came on. So I stopped the car got out looked and made sure everything was closed. I was driving down the road when the light would blink off and on when I went over bumps and what not. Is there easy fix for this. If it is the hatch sensor switch where is it located and can it be fix.
[Edited for easy reading]
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
It's kinda hard to read your post. You have a buzzing sound coming from the passenger door when the key is "ON"?
Try to isolate what portion of the door the buzzing is coming from. There's not many things that can buzz in a door on these cars.
And as far as the light going on and off, it's either your passenger door or your hatch. More than likely the hatch, though, since it's going off when you go over bumps. It's going to be the sensor switch in the hatch that tells the car the hatch is closed.
greendusk
Yeah, I cleaned it up sometimes I am just typing with out thinking. but yea the sound comes on with the key is "ON". and it seem to be coming from front of the door. Like in the area of the vent and door handle.
greendusk
[youtube]http://www.youtube.com/watch?v=s3s-ZgozcFc[/youtube]
Yeah at 1st it was sounding like it was coming from the door but it is coming from the light. Also turns out that it is the right side door that is not closing all the way. There does not seem to be anything stopping it from closing.
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
greendusk wrote: Also turns out that it is the right side door that is not closing all the way. There does not seem to be anything stopping it from closing.
The doors on these cars are heavy and chances are yours has likely sagged over time. Write up below should fix the issue.
http://www.ttzd.com/tech/dooraligntech.html
robomatic12
Car: 1990 300ZX TT
The noise is the climate control fan, I believe it feeds interior air towards a sensor which tells the climate computer what the temperature is inside the cabin.
If you pop off that piece of trim you will see the fan, try cleaning it and spraying some lubricant on the shaft. **It's underneath the piece of trim with the overhead map lights you have in the video
greendusk
Thanks both project will be done this weekend.
MyLadyZX
Car: 1990 300ZX Non Turbo
I had that same problem in my drivers door and after i fix/replaced my fuses it hasn't done it again.
islandtuner242
Car: 1990 Nissan 300zx N/A 2+2 SOLD!!!
2003 Infiniti G35
@Robomatic do you know the part number for the climate control fan that you talked about cause i'm having the same problem
