what is stock piston size?
fmf221
Car: cars
on a sr20det....86 mm,or is that wrong?
godspeed
this is from http://www.srswap.com got to love these guys...good luck what c/r are you looking at going with, i am thinking of rebuildding one too, but not sure on the c/r to go w/Specifications
180SX 91-93 and Silvia 91-93
Displacement: 1998cc (2.0 liter)
Cam type: DOHC 16 valve, chain driven cam sprockets
Bore and stroke: 86mm x 86mm
Compression: 8.5 : 1
Horsepower: 205ps at 6000rpm Torque: 203 ft/lbs at 4000rpm
Stock boost: 7 psi
Throttle body bore: 60mm
Turbo specs: Injector size: 370cc/min
Compressor: T-25, 60 trim 56mm BCI-1 compressor.
Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing.
Center Section: Journal bearings
fmf221
Car: cars
im going to get a s13 blacktop with wiseco pistons,8.8:1 compression w/ 86.5 or 87mm.i dontknow if i shouldgowith flat top or not.crower billet rods,hks cams and a whole bunch of good stuff.its all goin in a 95 240,makin it a sleeper.its gonna be crazy,but it wont be finished for like 2 years.
whatdoes everyone think?flat top,or regualar?
ImportIntelligence
Car: Big turbo's :)
Just a thought, if you are going to replace stuff in your bottom end replace the thrust washers for good measure. They are the 2 half moon looking washers on the #3 bearing cap. They do wear out after running on high boost for awhile.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
I have a set of Race Engineering (made buy wiseco) 9:1 86mm pistons that are going into my engine when I have the time.
Bussman240sx
Car: Nissan cars, and women
86x86
godspeed
ItzGenX why did you go with higher c/r ...im trying to decided if i do it...please let me know, does anyone know if the stock rods are that bad, how much can they take?
GraySilvia
Car: auto-x, drag racing, beer
Hey fmf221, do you realize you can't just bore out an SR20 like everyone seems to think you can? You can't just buy an off the shelf 87mm pistons, bore the block, and be done....you bore off the cylinder coatings. Well, i take that back...you CAN bore it and run like that, but it won't last long. These aren't iron blocks as you all know; you can just bore them....such is the burden of superior nissan technology :)
fmf221
Car: cars
yea i just relized that seriously 5 min. ago after reading the re-sleaving topic,im a ****in moron sometimes.im gonna go with the race engineering 9:1 compression 86mm's.
ItzGenX
I have 9:1 pistons because it will have a torque increase, better power when I'm off boost, quicker spool-up, more power per psi of boost, and slightly better gas mileage.
TonyMontana
say u got a 2.2L stroker kit, but used 9:1 comp pistons
that would give u both increase in torque cuz of the extra displsement and comp ratio right?? (no experience with turboes yet)
so say u did that, would u be able to hit 400rwhp on pump gas still?? or would that be out of the question??
and say u couldnt with pump gas and had alky/water injection, would that make make it possible?? and if so, would the block be able to take it??
TonyMontana
and is it possible to just order the jun crank and rods, or toda crank and rods, and buy your own pistons to your specks
ItzGenX
Yes.
No water/alchy needed to hit 400hp, even on a stock 2.0L.
And Yes, You can get custom specs on pistons to make a stroker work without boring. (86mm pistons)
TonyMontana
oh, so when i do order a jun stroker kit, i can tell em what bore and comp ratio i want with it??
ItzGenX
Quote »oh, so when i do order a jun stroker kit, i can tell em what bore and comp ratio i want with it??[/quote]
LOL no! What you want is to order the crank and rods only. Then go to another company and tell them the specs of the motor so they can make the piston. For example, I go to jun and buy a long stroke crank and stroker rods. Then I measure everything out and check all changes the engine is going through. After I find out all the clearances and measurements, I call up a piston manufacturer like JE or Wiseco and tell them the specs I need for the pistons.
