I've read on past threads that there is a way to check fault codes from the ECU without Consult (but can't currently find that thread). I'm wondering: if there is a fault code, does that also trigger the dashboard "idiot light" information panel to read "check engine" or something similar? Or put more simply, if my dashboard info panel has no negative messages is it still possible that there is a fault code recorded?
Tom - 91 Q
