What is needed to swap a RB into a 240sx? *FAQ*
slowmz3
quick question, i'm sure has been answered before.
so, if you buy the after market full adjustable mounting kit for the rb20 to throw in a s13, will you still need the rb20 crossmember? granted, the clip will come with it anyway.
thanks!
redman
Car: 180sx RS13
which model of aluminium radiator can I put on 180sx with RB20DET swap?
Koyo or mishimoto for CA18 , SR20 , RB , other ??
1990tsi
Car: 1989 RB20DET S13, 1990 Skyline GTS-T
The $$$ mounts are for the S13 x-member.
using the R32 x-member saves you the $$$ in mounts, although you need to notch your hood and will require special attention to the turbo elbow. Turbo wlbow may need work with the $$$ kits as well, I havn't used them before.
My front sway bar hits the oil pan a bit as well, $$$ mounts should get rid of that.
RizzoTK
Car: 1990 rb25 s13 project
I have a previously sohc s13 that now has a rb25det (using r32 x-member and syko mount kit) I also have the Greddy intake manifold. My ? is what throttle cable have you guys used? my sohc one is not long enough.
1990tsi
I'm using a SOHC cable, but with your intake manifold being different you should need a different cable. I don't know which cable to reccomend, you'll have to measure and see how long you need, and nissan should be able to help you out after that.
As for the Turbo elbow/Downpipe clearance issue, I have found a solution!
Pics and description will come as soon as I get longer bolts to make sure it works as it should!
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
The throttle cable issue can be address by simply lengthening it with home depot supplies. Carl as well as others have covered it in these forums.
redman
Car: 180sx RS13
Does the SSA fmic for R32 GTST can will put on a 180sx with RB20 convertion ?
thanks a lot
Coolwhip
Vendor
redman wrote:Does the SSA fmic for R32 GTST can will put on a 180sx with RB20 convertion ?
thanks a lot
whatever SSA means ??? But yea, with alittle work you'll be able to use a R32 GTST FMIC kit on a S-Chassis RB swapped car.
redman
Car: 180sx RS13
SSA is just an example of fmic kit (SS Autochrome / XS Power)
yotik
Car: 240sx Hatch
did you ever find out if the bolts worked? and if so what was the solution?
KlanjacOFF
Car: Nissan 240SX
Alright so the FSM states to lube the CAS. What lube should be used? I was thinking white lithium grease.
KlanjacOFF
Car: Nissan 240SX
bump?
Butters08
Car: s14
i am doing an rb26dett into an s13 and had some trouble fitting the rb25 oil pan on that i was told to buy. first off the 25 pan is too shallow be about a half inch for the 26 oil pickup. also the baffling plates on the motor and the oil pan do not allow clearance in the rear. to fix this i used a n sr20 oil pick up and it bolts right up perfectly. and simply broke the spot welds of the rear baffles on the oil pan and removed the rear baffles fins on the motor itself. the edge of the oil pan touching the pickup needs to be beat out a little bit and the lip flattened with new hole drilled to fit the factory holes . any questions just reply cause this all worked for me.
viral5523
Car: 95 240sx
Just wondering, Would I need an aftermarket Radiator/specific for the RB25 swap? Could I use just new radiator hoses for my KA24 Aluminum Radiator? Im asking becuase the list does not specify and it would suck to have to buy a new one.
Butters08
Car: s14
i would strongly recomend using an aftermarket koyo rad that is for the ka cause that will bolt right in and the outletswill match that of the 25 and of course get new rad hoses a total of 325 dollar may be spent but its very well worth it.
Butters08
Car: s14
i would get a koyo for the ka cause the outlets will match the 25 and its well worth it
viral5523
Car: 95 240sx
I already have a full aluminum radiator, thanks for the info. I just wasnt sure if the outlets would line up. I made a list with estimated prices. (Let me know if there is anything I may be missing)
RB25DET Swap Into ‘95 S14 240SXParts Needed:RB25DET Engine RB25 5spd TransmissionRB25 MT ECURB25 Complete Engine Wiring HarnessIgniter ChipMAF SensorIntake ManifoldExhaust ManifoldTurboAlternatorA/C CompressorFuel Rail & InjectorsPower Steering PumpStarterCoil PacksClutchFlywheel Above Estimated Package Price: 2400.0
Other Parts needed:Custom Drive Shaft (One-piece preferred) 450.0 (McKinneyMotorsports.com*/Off-Road Shop)Custom DownPipe (3-Inch Mandrel Bent) 220.00 (McKinneyMotorsports.com/Muffler Shop)RB25 > S14 Engine/transmission Mount Kit 550.00 (McKinneyMotorsports.com)Front-Mount Intercooler(Black) 170.00 (Mishimoto Core)Custom Intercooler Piping 250.00 Walbro 255 Fuel Pump 120.00Clutch Kit 400.00Flexa-lite electric fans 200.00Custom Throttle Cable Bracket 25.00 (Or just make one yourself) Above Estimated Price: 2385.00
Recommended Parts:Accessory Belts (Gates) Alternator - K040335 16.00 A/C - K040358 18.00 P/S - K030328 16.00Water Pump RB25 170.00Oil Pump 290.00Timing Belt 130.00Spark Plugs 30.00Oil Filter 7.00Engine Oil 50.00 Above Estimated Price: 727.00
Total Estimated Engine Swap Cost: USD $5512
And all the work by myself of course.One more question, Assuming all goes well, how long would the swap take?
Modified by viral5523 at 7:23 PM 8/7/2008
Butters08
Car: s14
for the swap i would at least do ac delete cause that will ease some trouble of fitting the motor. tophatperfomance.com has motor mounts for the 25 and 26 that are only 299.00 dolla and they are pretty decent and can save you money. also i would buy a new slave cylinder cause they usually cut those off. they are like 60 bucks. when i think of more i'll let you know
viral5523
Car: 95 240sx
Sounds good, If I were to get the tophat mounts, I would have to go to a local shop for the driveshaft correct? or would the mckinney shaft work?
Butters08
Car: s14
actually you can buy a drive shaft from top hat for $399 that fits great.. i bought my mounts and drive shaft from them.
Butters08
Car: s14
when you go to put in your rb using the top hat mounts they will tell you u only need to knock about an inch on the passenger side firewall but they are lying. i found out the hard way cause i had to pull my 26 out 5 times and keep hammering until it fit just right. so basically knock it out all around as much as possible.
Butters08
Car: s14
all inall the swap was ok considering i did an entire rb26 swap into my 90 240 hatch all by my self literally none of my friends helped. so good luck with yours
viral5523
Car: 95 240sx
Well considering I am doing the RB25 swap into a S14, would I have to hammer it?
Butters08
Car: s14
i would recommend it simply to save time during the install
viral5523
Car: 95 240sx
Where exactly would I have to hammer it? Right above the transmission, where it meets with the engine? I really do appreciate the advice, thanks.
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
starter area
yotik
Car: 240sx Hatch
what transmission mount is everybody using for the rb20det into s13?
S13Ricky
Car: Chenvy Cobalt SS/SC
Damn it, I was hoping that the RB26dett swap would stay under 4 or 5 k. That is if I can find an RB26dett for under 1k which is possible with the right connections. How much have you guys spent on the RB swap?
DJButton
Car: 2010 Nissan 240sx
it's not cheap at all to do it right man, I spent $4,500+ just doing an RB20 swap. Add another 2k easy for an RB26, I usually say prepare to spend 10k on doing an Rb26 swap properly.
yotik
Car: 240sx Hatch
S13Ricky wrote:Damn it, I was hoping that the RB26dett swap would stay under 4 or 5 k. That is if I can find an RB26dett for under 1k which is possible with the right connections. How much have you guys spent on the RB swap?
So far ive spent 2100 on the rb. My guess is 4500-5500 when its all said and done; which i have deduced means i have quite a bit left
