Or not buy a front clip.ddgsxr504 wrote:Buy a Front clip.
You get the sidemount IC, and everything else you need to do the swap. The only thing you will need to buy is an upgraded fuel pump, downpipe, and a couple gauges.
oh hell no I wish. Thats the style body kit I'm going to do on my car when I get it.brandonlgilbert wrote:Is that the S14 you are trying to buy in your sig? Got more pics?
Actually S14 SR into S14 240SX is pretty straight forward. Besides the harness needing to be lengthened and shortened there are only 3 wires that need to be re-pinned/rewired.redtop91 wrote:It does matter. The wiring of an S14 SR into and S14 is completely different than an S13 SR into an S14. One is not necessarily easier than the other but they are different.
yes, of course. The price includes things like DP, FMIC, Headgasket, new oil pump, fuel pump, etc etc.kornmanz wrote:was that 5k with u installing?
So what do you mean? Which parts in general?steeda763 wrote:The installation is pretty easy; it's absolutely not worth having somebody install IMO. Plus you get all that satisfaction when you do it!
I went with Heavy Throttle back before they did the whole "swap package" thing that they do now, and even then I had pretty much everything I needed minus the intercooler (I went FMIC anyway). They are a little more expensive but you definitely get what you pay for. The swap packages are a great deal I think, actually.
Replace as many parts as you can afford. It'll save you headaches down the road...especially if you have a crappy T25 turbo. Lol
oh yeah for sure. I have a cherry picker so I'll be able to build what I can on the engine before putting it in. I'm going to basically do exactly that. Take apart the whole engine and then re-build it with new parts..I want that thing to run really great for as long as I possibly can.steeda763 wrote:Well, I meant to say replace as many worn/broken parts as you can during your swap. Parts such as motor mounts, hoses, connectors, P/S or coolant reservoir, radiator, master/slave cylinders, etc. Check over your engine and replace anything that might be bad on it. The power steering rack might need some attention as well (mine did). Parts that look like they might go bad will go bad, and replacing them up front and with the engine out will save you a lot of stress later on.
Also, if you plan on upgrading your clutch and/or flywheel at all, do that during the swap.
