What is needed for a E to DE swap?
sykane
I am currently looking for a 240 and found 3(!) in my area that match what i want(a 5 speed).The only problem is all 3 are either 89 or 90's.What i wanna kno is how hard is it to swap a DE in? IS there anything else needed other than the engine?Will the trans work fine? Also i hear that that using the pistons from a SOHC engine are higher compression than the ones in the DE so u can use them in it. Is this true and would it be smart for me to do once i swap out the SOHC for the DE?
SeVa-S13
Car: '05 GTO 6spd
What's wrong with the SOHC? There's plenty of aftermarket out there for it, has a better low end, and that miniimal gain from the DOHC is hardly worth the trouble of a whole swap if the engine's fine.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Wiring harness and gauge cluster... from what I understand, the SOHC and the DOHC uses different tach signals.
black s13
you need the engine, tach, engine wiring harness, ECU, coil and all the power steering stuff (lines, resevoir)
Altiman94
Car: 1989 Nissan 240SX
leave the sohc. Instead of spending money to swap the dohc, piece together a turbo kit
wangless
Car: '02 MBP WRX
not to threadjack... now what would be better... turbo ka24e, or turbo ka24de ??
i2ice4m3
Car: COUNTERSTRIKE!
lol you hella threadjacked
wangless
Car: '02 MBP WRX
sorry, first thing that came to my head :(
you guys dont have to answer... ill just stay in my corner, alone...
