Q45tech wrote:No they didn't.2 failed [replaced 4 in odd bank] last May [2008] at 316,000 miles, now 2 more are failing on the even bank. At 323,000
The injectors started failing 6 weeks after E10 was introduced in Georgia gasoline. Since then we have replaced multi- hundreds of Q45 injectors whereas 1 per year was high in the previous 10 years.
At least I know brand new oem injectors will last 1 year and at least 7,000 miles in the presence of E10.
Tech, could you briefly elaborate on "are" failing? How did you diagnose this, and what led you to investigate?
I'm curious, because I just reassembled (with great regret) my injector rails when doing my KS's. I wanted to send them to Deutscheworks but didn't have time or money to do so, and will be in there soon I presume to reassemble. I'm hoping for a large change after 180k miles. Some of the pintle caps were bad, and the injectors looked filthy, seen here:
http://www.youtube.com/watch?v=plbvv77tKHk
I'm just curious to see what makes you say they "are" failing.
