elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun Dec 26, 2004 4:11 pm
I am looking at some new tires (even though I dont need them)
The optimal size for me to run on my Q is 255/45-17 and 255-40-18.. however, these tires are expensive for something good..
255-45-17
Sumitomo HTRZ II... 98W, $112
Kumho ECSTA MX. 98Y, $125
255-40-18
BFGoodrich g-Force T/A KDW 2.. 95Y, $180
Bridgestone Potenza S-02.. 95Y, $229
So Im not too pleased with these load ratings, as Tech just said in another post a lot of handling can be had by just having a better load rating.. So I looked at some 255-50-17 and 255-45-18.. The problem is there is a 4% difference in speedo..... THe tires are a perfect match, but Im not sure I like the difference in the speedo.. The load ratings make it seem more worth the price...
255-50-17
Kumho ECSTA Supra 712, 101W, $107
255-45-18
Sumitomo HTR Z II 99W, $161
Now looking at the prices, the difference is minimal... However the load rating makes me want to do it, because it the same width, but a taller sidewall for better load handling.. Theyre all considered Z rated (150mph+) so the sidewalls should be really stiff...
Thus, I ask, how might one calibrate the speedo in the Q for this.....?
EDIT.. Let me add there is a 4% variation between the larger and the smaller size... the 255-45-17s match up perfectly to OEM.. the 255-50-17 are 4% different.. The corresponding 18in tire i listed matches perfectly to the 17 i listed.....
