PoorManQ45 »
https://forums.nicoclub.com/poormanq45-u17729.html
Thu Jul 28, 2005 3:26 pm
Oh no! You're using the stock HU without the amps!
The OEM HU ONLY feeds a LOW voltage signal to the amps, there's less then 1watt of power there. If you're using the OEM HU you NEED the amps hooked up.
Otherwise you'll need an aftermarket HU.
