What is gonna happen if I unplug the battery?
Wolv
Car: 2009 Nissan Rogue SL AWD
I was gonna unplug the battery and clean the terminals cause there is some corrosion on them. If I do that , what am I gonna loose? Like do I need a code for radio or am I gonna loose keyless remote ? Thanks.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Do you need a code? No
Will you loose keyless remote? No
Will you loose the station presets? Yes, unless you use an Automotive Settings Keeper w/Battery - Keep your Personal Settings when Replacing your Car Battery.
Wolv
Thanks,I don't think I can use automotive settings keeper cause my power cuts off from cigarette lighter when the car is off. So other than station presets I won't loose anything? Like I don't need to do anything special after disconnecting and reconnecting the battery? Thanks.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Actually did it recently, cleaning and then replacing battery. So a couple times.
The usual is having to redo all my stereo settings.
I also like to use the trip b odometer to show how much miles I did for my last oil change. Those reset, so I hate losing those readings.
Lastly, the relearn programming for your driving, I don't really notice.
That's it for my experience.
Wolv
casperfun wrote:
Wed Aug 30, 2017 10:41 am
Thanks for the reply. What do I have to do for the relearn programming for my driving?
Return to “Rogue Forum”
