noskatehate22 »
https://forums.nicoclub.com/noskatehate22-u160488.html
Sat Jul 03, 2010 2:14 pm
So I swapped the two green relays after I learned that one is for the fuel pump and one is for the fuel injectors. I know the fuel pump is pumping, so I swapped them and same result; fuel pump is pumping, no start. So now I pulled an injector and the tip seemed a little damp, but I dont know if it was like that before I pulled out, or maybe some fuel dripped on it when I was pulling it. So if it was damp, im guessing that means the fuel injector is working, but the fuel is not being ignited, therefore it could be coilpacks/plugs/wiring/ignition control module. And if it was dry, im guessing that means the injector is not spitting out fuel and it is clogged! Anyone agree or disagree? Or any other suggestions?
