thats good $hit mangDrifterProdigy85 wrote:1st - 40mph - 3.3212nd - 70mph - 1.9023rd - 101mph - 1.3084th - 132mph - 1.05th - 174mph - .759
Calculations done using stock 7500rpm redline, 4.083 R&P, and 195/60-15 tires.
thanks a ton!DrifterProdigy85 wrote:1st - 40mph - 3.3212nd - 70mph - 1.9023rd - 101mph - 1.3084th - 132mph - 1.05th - 174mph - .759
i would liek to know how an 8000 rpm redline and 275/40r17 would affect those numbersDrifterProdigy85 wrote:1st - 40mph - 3.3212nd - 70mph - 1.9023rd - 101mph - 1.3084th - 132mph - 1.05th - 174mph - .759
oh i think my car will have enough power. i am getting the HLSD s15 but i am not going change the rear end ratio so that will stay the same as the stock but the transmission is the sr20 and it is stock....... i think if i had a god long road i might try for 170 but other then that probably not it is scarry doing 140Tulsa_S-13 wrote:
This is using a final drive of 4.08:1, Redline 8500rpm, and 275/40/17 tires.1st - 45.07mph - 3.3212nd - 78.70mph - 1.9023rd - 114.44mph - 1.3084th - 149.69mph - 1.05th - 197.22mph - .759
However, DrifterProdigy85 used the 5th gear ratio of the KA24 transmission. In the SR transmission the 5th gear ratio is .838
So 5th would really be:5th - 178.62mph - .838
You would need quite a bit of power to come even close to that, not to mention better aerodynamics for stability purposes
Actually my S14 SR20DET FSM states that the gear ratio of 5th gear is .838, as does http://www.200sx.org/faq_2.html . Maybe the S13 SR uses the same ratio as the KA but the S14 SR does not, I'd be curious as to if it does.DrifterProdigy85 wrote:The SOHC KA trans has a .838 5th gear. The DOHC KA and SR Trans has a .759 5th gear. I use this calculator. http://www.f-body.org/gears/
Your calculation for those 275/40-17 tires and 8500rpm are wrong. The 275/40-17 tire is 25.6" diameter compared to the stock 195/60-15 tires being only 24.2". The 275/40 tires are 5.6% larger making the speed difference much greater at higher mph.Tulsa_S-13 wrote:
holy sh*t i wonder how long of strech some one would need to hit that lol. i wont ever go that fast. hahaDrifterProdigy85 wrote: 275/40-17 tire is 25.6" diameter compared to the stock 195/60-15 tires being only 24.2". The 275/40 tires are 5.6% larger making the speed difference much greater at higher mph.
1st - 48mph2nd - 84mph3rd - 122mph4th - 159mph5th - 209mph (.759)5th - 190mph (.838)
Actually my calculations weren't wrong and are the same that are on websites such as http://www.f-body.org/gears/ . I calculated them for 8k rpm 275/40/17 because those were the parameters that Idahotuner was wondering about and for some reason I mistyped the rpm value in my post. Let me edit my post so the world keeps on spinning.DrifterProdigy85 wrote:
nice nice it helps alotDrifterProdigy85 wrote:1st - 40mph - 3.3212nd - 70mph - 1.9023rd - 101mph - 1.3084th - 132mph - 1.05th - 174mph - .759
