vq35de »
https://forums.nicoclub.com/vq35de-u7384.html
Wed Jan 07, 2004 3:25 am
the nissan trannies only limit your top gear, the transmission will still downshift normally to any gears below the one you selected. so if you select "5", the transmission has all the gears it is used to and will act normally.
It may or may not lock-up in 5th, I think that is a TCU logic check to make the T/C lock up only under certain conditions (one of which is the selector is in D). the AT G35 has the same transmission as your M. I have a copy of the AT G35 ESM at home. It should have the exact same logic as your M.
IF it is as I said, then you should feel more torque in 5 than D while cruising in lock up conditions (translated to quicker throttle response when not locked up), but if the TCU logic decides that the T/C shouldn't lock up while you are cruising in D, there will be no difference.
