Matej wrote:No, Megan copied Apexi's design, they are the same thing, literally.
Both coilovers are made by the same suspension manufacturer. The main difference are the specifications they're made to. APEXi has certain specifications to make the coilovers, as does Megan. Aside from the appearance, the main difference is in the damping of the shocks/struts. Spring rates may be different, but as stated before, they manufactured them to APEXi's specifications.
If you look at it, it's like that for many, many parts in the auto world. Cusco's clutches are Exedy pieces with Cusco's specs to make them a tad different; KYB makes shocks for many suspesion companies (i.e. Tanabe, etc); HKS turbos are Garrett of Japan; etc, etc.
Hope this helped a tiny bit.
